Multiple Kangaroo Physics Engine
Hello everyone,
i was wondering if it’s possible to use two Kangaroo Physics Engine in one grasshopper work sheet. As you can see in the picture and the attached files I have two steps in my analysis. The structure that I’m trying to analyse is Origami based. So I use a origami-cluster to first build and create the structure. In a second step I want to apply a load on the structure and see how the deformation in the structure are. So i thought that adding a second kangaroo physics engine would be a good option for this problem but the seconde engine always gives the error: “out of index range”.
Can anyone help me?
Thank you in advance.
Origami_simplified_Final.gh (174.4 KB)
