Hi all,
As the title mentions, I have found that when using the multiple curve intersection component there seems to be some kind of intersection tolerance build within the component script.
See the attached definition where I have some sample lines where the default size finds 3 intersection points but the scaled version (x1000 factor) only finds two which would be the correct output from visual inspection.
Now I got around this issue by scaling my model from meters to millimeters but I would like to understand what is this tolerance value and if there are any options to edit it in the case I am dealing with small details. I believe it is against the terms of service to dive into the components code and modify things there.
Multiple Curves Intersect Tolerance.gh (7.8 KB)
Thanks,
Arthur
