Multiple Annotations for the Same File?
I would like to create a different set of annotations for the same file for different purposes.
That might be accomplished by incorporating by reference and readonly a file into multiple files where the annotations are added.
Is there some simple way to do this in Rhino?
Hello- if you insert the annotations as a linked block you can change which linked file is being seen by that block.
