Multipipe issue
I am having an issue with multipipe- I am sure it is a pretty easy fix, but I have done some looking around and and not sure how to fix it. File attached.
I want a smooth finish, and there are some straight very thin parts that I don’t want and I am not sure how to get rid of.
Thanks in advance!
multipipe issue.3dm (646.1 KB)
i am quite sure you have to build the section transition with the 3 branches on your own:
the typology might look like this - still can be optimized … a first fast go:
as tom mentioned, build it in three pieces, then delete faces / stitch edges to get what you want-
see my go at it here-
multipipe issue_kfix.3dm (392.5 KB)
@DanielPiker may be able to chime in on why that joint is failing. It may simply exceed the number of curves MP can handle at one time to make a joint.
Ahh this makes sense! Thank you!
Thank you!
Circling back to this, I think I understand the principle- I would have to build it using the paper doll technique which I can do- but how then can you get it to curve into a ring shape? Thank you! @theoutside
check the commands:
_bridge
_stitch
do a test-run with 4 cylinders with 8 arround faces each.
I just multi piped the curves a few at a time, so as not to make too crazy of a joint, then deleted faces and then stitched the pieces together as needed.
But, making it flat then flowing it along a curve or surface is a totally valid approach.
Ahh ok that sounds good. Thanks!
