Multipipe Broken Output
I am trying to use multipipe to generate a pipe lattice but the generation and out is broken. It generates the lattice alongside strange, elongated artifacts. What is causing this and how can I fix it? From testing, I have traced the issue to specific hexagons that if included in the multipipe cause the issue. Yet if those hexagons are multipiped by themselves they have no issue. I also can not find anything unusual about those specific hexagons nor any commonality between them.
Some of your curves are too short for the diameter.
It may also be that your curves have too many control points.
I’ll check that. Though now I’ve got it working but I don’t quite know what the exact issue was. I ended up deleting the hexagons where the issues originated and that fixed it. Maybe there were two curves on top of each other as deleting the issue hexagon didn’t leave a hole in the lattice.
Explode all polylines then seldup to select duplicates…
