Multiline data
Hi all!
I would like to ask you for some small help with list managmenet. I have a list of properties and I need to take some of them, modify value and create a smiliar list (it will contain only few positions). Here I have 2 questions:
  1. Is it possible to “merge” in this case 2 panels (“horizontal” and “vertical”) so values will be under the same index “0”?
  2. Names of properites like B_H_ext or B_V_ext are fixed but I would like to be able to change values 500. Is it possible to connect somehow a slider so I can easily change value insted of editing panel each time?
Maybe there is some totaly different approach to create this kind of list that I am not aware of.
I would be gratefull for any help :slight_smile:
maybe this would work for you?
multiple_concats.gh (11.6 KB)
That is perfect! Thank you so much! :smiley:
ahh, if you have many strings you can also save some clicks by using same principle with text join:
multiple_concats_re.gh (10.8 KB)
