Loft multiple along railEW.gh (28.1 KB) @ZY_Night On the forum please do NOT use plugins. Your solution can only be seen, if the readers also install the same plugins. And most of them do not want to do that (at least I do not The ‘challenge’ is to show how it is done with common components.
Thank you! How can I sweep “through the profiles” rather than along the rail? I noticed the sweeps cross at the end, do I need to mirror the last perp frame?
Sorry for the belated reply. I assumed you solved your question.
anyway. the cross at the end is, because two planes were used in the orient.
Just select on (list item) and then this is solved.
