Multi input and multi output, assign the reference geometry in all input
12
Hello!Everyone … What I want to do is place a small rectangle in multiple larger rectangles that I have assigned. Currently, I am only able to place the small rectangle in one of the larger rectangles or in a list of assigned items. Can you help me figure out how to place the small rectangle in all the larger rectangles that I have assigned? Thank you!..who have answer kindly explain me.
Hey is it an option for you to use grasshopper? There i think it would be fairly easy to do
I am currently working in Grasshopper, but I am struggling to come up with a script. If you know any scripts that could help, please share them with me.
Maybe something in this direction?
MoveRectangle.gh (9.7 KB)
Perhaps move this topic to grasshopper
Just realized I used the pufferfish plugin to create the rectangles, but you can also reference your rectangles (Maybe needs some logic to have the segments sorted all the same way)
Thank you, Brunold. Your help has been great. I’m trying to place an insert box in a specific orientation. I reparametrized the curve, selected a point, and moved it around to the desired location using the graph. However, I want to place the red mark at the base of the rectangle on the exterior face,in all the rectangle
[/quote]
Screenshot 2024-02-07 203818
hi, anyone have a solution for this
Hey Dinesh
Im not quite getting it. So the goal is to move the trapeze to the blue marked positions?So it would need to rotate and scale? I cant follow quite the logic
Best
Felix
Hello- I do not see how to tell which side you want the object to align to unless you do them one by one - is that acceptable? In Rhino: Orient > Snap to mid and one end point of the base of the shape, as targets snap to mid and one end point of the rectangle side to align to, Scale=No.
With the help of the gene pool, I can reparametrize the curve and adjust its location. What I need to solve is how to place the base curve on the other curves. Additionally, I want the vector plane to change direction on the exterior face.
14
