Multi height levels
Hi, I have a second story that has a raised slab in the middle because they were previously two buildings joined together with a third central building that had a different height slab. I have therefore placed the slab higher in the middle and steps leading down to the slabs on either side, but I’m not clear if there a way of jogging the level on the level manager?
Hi James,
In VisualARQ 3 it is possible to create buildings with different boundaries and therefore create jogged views of levels from the level manager:
so how is this done? Is this available on the VA 3 beta?
Hi James, yes. The Cut plane always cuts through the last visible level in each building.
