After my last update of WIP to Rhino Beta, MSplit command isn’t dividng the mesh anymore as it used to do (same examples that used to work in the past), instead it will keep the full mesh as as output “Below” or “Above” but it won’t divide the mesh in two separate parts anymore.
Attached you can find an example of the definition I am talking about. Any thoughts?
Thank you so much.
MSplit issue.gh (313.7 KB)
Hi, if anyone experienced a similar issue, I found that with this week update, version: 7.0.20280.13133 MSplit is now working fine again.
Regards
