Moving Text in Layout Space Issues
Noticing that if move text in layout space or model space with the gumball or the move command, the gumball orientation gets skewed and does not center on the newly moved text. See attached images
Hi @brady1 can you post a simple example where this happens? I am also getting weird behavior with text but not this exact behavior.
Hi Brady - Has the text been scaled? Ah, ok, think I see what you are showing:
Make some text. Select it with Gumball enabled. Drag via Gumball. Deselect. Select it again - the Gumball has moved.
RH-72214 Gumball: moves relative to text
Yeah, you got it.
