Moving supports and point loads on a beam
Hello everyone,
I have the following problem. I would like to have the supports on a solid concrete beam not at the edge but 10 cm away from the edges. I have implemented this as shown in the example: Simple Supported Beam - Karamba3D
Now I want to have two point loads 40 cm and 80 cm away from the edge. However, this does not work as I now have these point loads on every line created (see file). Does anyone have an idea how I can implement this?
Beam-concrete.gh (47.0 KB)
Hi, you need to simply split your beam at those specific points and then apply the supports and those loads.
Hi, but how I’m able to divide the bar at these points?
I got it to work. However, I had to discard the “Concentraded Beam Load” component and use the “Point Load” component. This should not lead to any changes in the calculations?
no, the application is the same so there are no changes in the calculation
