It’s possible to move one single sub-d vertex without affecting the position of the other vertices?
Thanks , Roy
Hi @lopez
If you sub-object select (Ctrl+Shift select) a single vertex and move it, the other vertices should stay in place. It will affect the surrounding surface, yes, but the vertices should stay in place. If you are not seeing that, there’s a good chance you have SoftTransform
turned on. Run the command with nothing selected to enable/disable it.
HTH, Jakob
Hi Jakob!
Yep, I had the SoftTransform turned on.
Thanks a lot,
Roy
