Moving Dimension Text
What settings do I need to change to get the fraction closer to the lines and closer to the arrows?
Hi John -
The feature request for exposing that setting is on the list as RH-63322.
I’ve added this thread.
A cosmetic issue:
On the settings, under ARROWS, the Arrow Size box rounds to thousands while the Leader Arrow Size rounds to ten thousands.
Hi John -
I’m not seeing that here:
Are you using a factory-default template, and, if so, which one?
I modified Inches Large.
