Moving control points using snaps with lock constrain
• as in the video I use Rhino8 bgut same in rhino9 for now, I lose the lock constrain (TAB) when I use the PerpFrom snap.
• Also, I noticed that I cannot use PerpFrom with a “nested” AlongLine snap, which would be useful to do this simple task…
How would you do this quickly without using guides, or adding any auxiliary construction line?
Have you tried using Smarttrack?
yes: in rhino smarttrack gets messy if you have other objects in the scene and it can happen that it inadvertently snaps to other snaps, hence I need to disable snaps, isolate objects… cumbersome to use smarttrack in my workflow.
I prefer to have the certainty to snap where I want with more precise available tools, as they are there in Rhino
