Moving a rebuilt planar deg. 1 surface edge - bug
Just stumbled on this.
  1. Make a simple rectangular plane surface
  2. Rebuild it to 5 x 5 points in both directions but keep degree 1
  3. Sub-select one edge, move it with the Gumball some distance
  4. The surface reverts to a plane surface (2 x 2 points)
Before:
After:
Tested in V7/8
Thanks, Mitch.
RH-76103 Moving an edge changes UV count
(also tested in v5 and v6 with the same result)
Also, if you move a control point so that the surface is not planar, dragging the edge keeps the 5x5 points but makes them planar again.
Before:
After:
Not sure if related, but I noticed that in Rhino 6 UV’s of planar surfaces gets swapped when you move edge of polysurface like this:
Hi Jari -
It’s possibly related but I’ve created a new YT item for this one:
RH-76125 Moving an edge swaps UV directions
