Hello Rhino community! New user of the software here, so this may be a very mundane question so thank you for your time.
I just finished meshing a lofted surface and I would like to expand out the middle set of control points. I lassoed them all and then did MoveUVN followed by adjusting the points by manipulating the N axis. When doing that, I noticed the integrity of the mesh getting lost.
Is there either a way to avoid this from happening or a way to repair it?
Hello - Weld the mesh at 180 degrees before using MoveUVN. But, I think I’d adjust a surface not the mesh - is there some reason you need a mesh at this stage?
