I’m noticing that the MoveEdge command in R6 BETA will sometimes cancel itself back to the Command prompt after windowing in a group of edges. Are others reporting this issue? Thanks.
Respectfully,
Brian Jackson
Respectfully,
Brian Jackson
Hi Brian - I have not heard of this that I can recall - if you have a repeatable case, please send it in with the ‘blow by blow’ instructions… But, that command is somewhat redundant now since you can sub-select (Ctrl-Shift select) edges and just use Move or drag them.
It seems I was also grabbing an edge that was part of a 2D block. Some things that import from AutoCad come in as surfaces. My bad for not noticing.
