Move wall by line
I want the wall to move according to the curved line to produce a result like this:
please help, thanks!
side
(1)
simple approach without scripting or grasshopper is to use cage-Editing
see
https://docs.mcneel.com/rhino/7/help/en-us/index.htm#seealso/sak_udt.htm
steps:
draw initial planar surface
_plane
make multiple copies
_arrayLinear
prepare deformation
_cageEdit
turn on cvs and edit the cage until the shape is as you like
_extrudeSrf (bothsides
(2)
design the target Surface /overall Shape that limits the rips. use this surface as cutter:
_plane
_arrayLinear
_trim (with the overall-Shape-Surface)
_extrudeSrf
Thank you. I was using cage edit and it produced a result that was similar but not exact, because the entire wall moved according to the curve, but I want only the section where the curved line was, to transform.
curve
Below is the grasshopper, any further help is appreciated:
dear @Jessica5
please post .3dm and .gh files so it is easier and faster to help.
its always a good idea to find a non-grasshopper, manual modelling technique solution before trying to do it with visual programming.
at least for one rip / element.
(1)
for cageEdit to work you should use a Boundingbox-Cage.
do not move the backside CVs
(2)
did you try this workflow ?
