Hi, I’m trying to move the Control point of a SubD surface with the “UVN Move” Normal slider , it moves nicely but the selection is not released only when I use the Escape Button it releases the selection but doen’t keep the normal move & go back to the original SubD
Is it a bug or it shoudn’t work
4 i close moveuvn window and SUB D maintain the modification ( control points are still on )
5 i press esc to hide control points and SUBD goes back to its original position , there is no way to maintain the modification
NOTE : if control points are moved with gumbal instead of moveuvn command when i turn off the points the modification is not lost
Hi and sorry for late reply,
I have found the reason ( bug ? ) : when i move 1 or more points along N by using moveuvn command , if these points are placed along simmetry line and if reflect is ON the subd update temporary according to N cursor input but as soon as i quit the moveuvn command the subd goes back to previous shape.
if i turn off reflect and make same procedure by using moveuvn N cursor on certer control points the modification is not lost once i quit the moveuvn command.
I think that when reflect is ON the moveuvn should still work same as when reflect is OFF.
(mac, v7.17)
it is a pity, that _pointsOn is required.
it would be really nice if selection of Edge / Face (Ring) would allow to moveUVN (without selecting the corresponding cvs).
