Hello Forum,
I’m currently working on an project for automating railings.
As i learned here: Copy object to another positions
I can compute one filling and move it to the other rectangles. But I’m running into a problem.
This is my computed filling:
Wether I use Move To Point or Rectangle Mapping, I always end up with this.
When I use my “test rectangle” it works.
(I’m using Perp Frames, because I want it to be an free geometry input)
I’ve already noted that it’s a different output datawise but i couldn’t determine why.
So I changed it to Move to Point, also tested it there with the actual line and an “fresh” Line from 2 Points, but I got the exact same result.
What am I overlooking?
