From set of different text i want to move selected
object at the distance of 2.02 mm from end point of the text.
But when i tried to move it actually moves
up to 1.76mm. I wish to have whatever input text i am assigning from the last point of input text
it should move the selected object to accurate point/distance i am giving.
From this text i want to move any single letter at the distance of 2.02 mm. But i need to move it from the end point of given text. I internalized my data even in last time. I don’t know why it is not shown up to you. Thank you both.
If you update to 2.7 you will have that X output. In any case you shouldn’t use move to point here as you are just moving in a vector x direction and don’t have a target point.
