Move starting point of curves normal to curve
Hi all. I do need to move the starting point of some curves tangent to the curve and I can’t find any reliable solution to do so. I already tried the Evaluate Curve which unfortunately don’t works and I am out of ideas on how I can solve this problem. Maybe it is something silly that I do overlook.
Please explain better what you want to do.
… and then in your picture we see black normal segments from the curves, not tangent…
I was in a rush…
That is. I already tried the use Evaluate Curve and get an “Parameter is outside of curve domain”. The issue it was that I was trying to feed the starting point of the curve at the input “t” instead to put the “0” value.
