Its for those cases when I dont expect to be moving something same as previous move, then realise I have to do so afterwards.
RepeatLastMove command, moves same distance XYZ as move just made.
or as an option in Move command.
No, but you can make the move simpler by using the Boxedit panel and some arithmetic.
Open the Boxedit panel and check that it is set to use World CPlane. Select the trace you have moved. Make a note of the Position co-ordinates in Boxedit (for example 5,7.5,10). Undo the move. With the trace selected note the new coordinates in Boxedit (for example -10,2.5,0) and subtract them from the first set of co-ordinates - this gives you the move vector (for example 15,5,10).
Select the trace and the photo. Run the Move command and for the ‘Point to move from’ enter w0 and for the ‘Point to move to’ enter w followed by the move vector values (for example w15,5,10.
