Move or extend Wall start and end points
Hi Guys,
Is there a way to move or extend the wall start and end points
by a certain length?
thanks,
Your are able to get the wall curve using the “Element Curve”… extend the output curve using grasshopper extend curve, then you can input your extension length on each side, then reinput the new curve in another element curve component input… this should update the wall using the new curve length
Thank you Mohamed, I will have a try, kind regards.
Hi Mohamed,
It looks like it works on the gh definition but didn’t apply to the revit wall?
create a new element curve component, and insert the newly generated curve into the C input and the wall in the E again…
Sweet! Thank you Mohamed, that is awesome, kind regards.
