Move objects on sublayers to a different parent layer
Hi Neil - thanks, I see.
take one parent layer and all its sublayers and move the objects on those to layers in an existing set of layers that has the exact same structure, and layer names that correspond in some organized fashion to the orignal set…
Delete the orignal layers.
@NeilE . @jcparks - see how this works as a test - Note: it currently does no checking to see if the layer structures match, it just assumes they do… it works in your test file… also does not handle nesting deeper than one…
MergeMatchingLayers.py (3.6 KB)
To use the Python script use RunPythonScript, or a macro:
_-RunPythonScript "Full path to py file inside double-quotes"
