Move Normal
Move Normal is a command that has been included in Rhino 7, right?
Do you have a sample source?
The Move command has a Normal option.
I know.
I would like to add Normal to the command options of a plugin I am working on, so I would like to have the sample source for MoveNormal.
Here is a C# sample that demonstrates how to move objects:
SampleCsMove.cs
To move normal to a surface, first determine the normal direction using Surface.NormalAt. Then based the translation transformation on this vector.
– Dale
Thank you so much:)
Is it the same theory as OrientOnSrf to select the target surface and move the object in the normal direction?
Hi @jack3,
A Circle has a Plane property, and a Plane has a Normal property. Base the translation transformation on this vector.
– Dale
