In both cases, I can’t stretch this object. When I use Move Edge and select half of the object it’s either doesn’t stretch or moves itself by the stretched distance.
Is your object created with extrusions? I have this switched off.
I have attached the two volumes. It doesn’t work for an open volume too and I can repeat it every time. no ME.3dm (217.3 KB)
Move Edges only works vertically.
Hi Piotr - DivideAlongCreases > SplitAtTangents = Yes will help. Here, extruding your curves does not get me a single surface all the way around like yours.
I need it working for Grasshopper.
If it was Rhino only, I would adjust the curve and then form a volume.
Actually, my problem was ‘no face merging after splitting the volume and creating the fill’. See image 2.
I started investigating and got to the basic of this thread.
I’m not sure which image this is referring to.
As for Grasshopper, to get around the creasesplitting issue, you could probably, in Grasshopper, explode the curve, extrude the segments, and then join the surfaces.
Not all faces are merged even being coplanar, and this is an issue I am having.
No MoveEdge is only side effect of it.
My units settings are very tolerant to errors
Hi Martin
It’s very interesting. I can’t explain it but your result is exactly what I expected (or wanted).
I assume you can move selected edges thus deform this volume.
