I create a GridSurfaceDomainNumber ball. I can´t move and I can´t delete the select part. Does anybody knows a solution?
Hi ede,
have you tried shrinking the sphere surface using the command _ShrinkTrimmedSrf ? This should delete the control points judging from your image.
c.
Hi Clement,
thousand thaks for your answer, now it works!
I´m a beginner in rhino and very happy to continue my work now!
Ede
no problem, this is the place to ask
good luck !
c.
Thanks!
Sorry to be confused, but what command did you use to create this? There is no GridSurfaceDomainNumber in Rhino. Is this Grasshopper?
Paneling tools, I think…
–Mitch
Hi Magaret,
Mitch is right, I used a panel tool, it´s called “ptGridSurfaceDomainNumber” in my version.
Ede
