Move curve with the length of another
I have the curve A with a certain length, I would like to move it with a slider that goes from 0 to the length of the curve B, as you can see, there is a domain already built, the value of this domain is the value that the slider should have.
Topic file 1.gh (6.2 KB)
Hi Ivo - try:
you got your solution, just a tip for when you use domains: there is no need to put the ‘zero’. It is the default value for the start of domains.
