Hi Pascal,
Thank you million times! It helped. So it is related to the plugin. Is this issue already recorded as a performance bug? And is there any chance for fixing it in forseeable time? Thanks
Petr
Hi Pascal,
Petr
Hi Petr, we haven’t heard from such a similar behavior before related to Lands or VisualARQ. Is this happening with any document or just with a specific one. In the second case, can you send it to visualarq@asuni.com so we can check it out?
Which versions of VisualARQ and Lands are you running?
Do you have any Section or Level Cut plane activated? (if you had a big amount of geometry and a section enabled, it might explain the slow performance, in comparision to the performance when no sections are enabled).
Hi Francesc. Well, in my case, I am experiencing this issue in bigger 2D drawing file. The larger the file is, the worse and more laggy are the commands move, copy, mirror, gumball etc. I was very surprised, that my new worsktation doesn’t handle such a file. But after disabling the VA, Lands and Tibidabo, it works much better and the difference is really visible! I am running the most recent versions of both VA and Lands (VA 2.3.6. and Lands WIP 6).I am not currently working in VA template, so I do not use any of VA commands and neither Section nor Level cut are activated. Plugins are just loaded to rhino, but I am not working with them within this project. I can send you the model in the evening, I am AFK at this time.
Thank you,
Petr
Hi Petr,
I’ve got your file, thanks. I have VisualARQ 2.3.7 and Lands Beta VII and it works fast and nice for orbiting, moving objects, etc…
Try this:
Let me know if the slow performance persists.
Hi Francesc, ok I’ll give it a try. I just wonder, @pascal, how did you know that these plugins could cause the performance problem? Do you have any experience with it? Or was it reported in past?
Petr
Hi Petr - it’s a reflex - if things go wrong in Rhino, blame a plug-in! Actually, of course we look for Rhino issues, but mainly it is pretty easy, to eliminate a plug-in as culprit by disabling it so that is often a thing to try early on when troubleshooting and occasionally it turns out to be just that.
so I installed VA 2.3.7. in the RH 6.12. The performance seems slightly better to me. But there is still visible difference. I tried to hit testmaxspeed command with VA enabled / disabled. The result is:
2 sec with VA disabled
5,3 sec with VA loaded
