Move command how to constrain to a certain angle?
I need to move an object such that the move adheres to a certain angle.
How is this done ?
I see no angle input for move.
Steve
Use the standard Rhino angle constraint (<45 for instance) when looking for the Move-to point.
Take a look at this Help topic: http://docs.mcneel.com/rhino/5/help/en-us/user_interface/cursor_constraints.htm
Thanks Pascal, that worked,
Margaret, thanks, no image in the image square though for this in that link .
Steve
You might think that I would suggest the Level II coursework here, but no! Level I:
http://download.rhino3d.com/download.asp?id=Rhino5Level1Training
-Sky
Which? Are you not seeing the video clips or the images or both? Do you have Flash installed on your computer? It is required for viewing the video clips in the help.
