Mouse Wheel
Hello ,
I need disable the zoom, any way to disable the zoom wheel function on c# ?
Or set the viewport to fixed size (zoom)?
Thank you
You can use RhinoCommon to access set/get the Zoom Scale Factor from Options, if set to 1, zoom is disabled.
Not sure if there is a cleaner way.
–jarek
Thank you @Jarek, I think that can work fine, but, I dont find the rhinocomon command
example.
can you please post some simple example?
thanks
hi @MatrixRatrix
I don’t speak C#, but in Python via RhinoCommon you can do it like this:
    import scriptcontext as sc
    import Rhino.ApplicationSettings as appsettings
    #get zoomscale
    dbZoomScale = appsettings.ViewSettings.ZoomScale
    #set zoomscale
    appsettings.ViewSettings.ZoomScale = 1
hth,
–jarek
Thank you
@dale, I need acess to delta mouse wheel event, there is any way? Any callback for the whell mouse?
Thanks
Hi @MatrixRatrix,
There isn’t anything in RhinoCommon that will provide this. Why do you need it?
– Dale
Hi @dale, I need use the delta wheel to rotate a selected object.
I set the same funcion (rotate) with a keyboard Key, but I now I whant use the mouse
wheel.
I already set the zoomscale to 1, so, I think the zoom is not go be a problem.
Any Idea?
No, I’ve got nothing, sorry.
– Dale
Hello @dale ,
After some searching work I found the solution:
Now I have a small problem, which I have already solved,
but I think there may be a more efficient way.
This method runs with the focus on rhino or without the focus on rhino,
I want the method to be run only when the rhino is focus
There is this function to set the rhino focus:
Rhino.RhinoApp.SetFocusToMainWindow()
There is any to check is rhino is focus?
If (Rhino.IsFocusMainWindow()??
Thanks
Yes this can be done using P/Invoke calling native windows functions like so:
IntPtr foregroundWindow = GetForegroundWindow();
IntPtr undefined = (IntPtr)(-1);
if (foregroundWindow == undefined)
  // unable to find any foreground window
  return;
GetWindowThreadProcessId(foregroundWindow, out uint processID);
uint currentProcessID = GetCurrentProcessId();
if (processID == currentProcessID)
  // Rhino has focus
else
  // Rhino does not have focus
You have to define the following P/Invoke extern functions:
[DllImport("user32.dll")]
private static extern IntPtr GetForegroundWindow();
static extern uint GetWindowThreadProcessId(IntPtr hWnd, out uint lpdwProcessId);
[DllImport("kernel32.dll")]
static extern uint GetCurrentProcessId();
Thank you for your answer, this was also the way I thought to solve it, I thought there could be a simpler way with rhinocommom.
thank you.
Not that I know of. If there is I’m interested as well :slight_smile:
