Here the mouse settings are not remembered in Properties.
After a couple of restarts settings auto-revert to default.
thanks a lot
Akash
thanks a lot
Akash
Hi Akash - thanks for the report, I’ll test here.
Did you also install the Mac Rhino 5.5 service release candidate?
This is required so the V6 WIP and V5 can share Preferences.
install and run prior to running the WIP.
thanks
And yes I have updated to V5.5 before installing the WIP
the WIP is very nice the more I work with it the nicer it feels, thanks a lot!
*a small additional thing to mention: the setting for the size of the setting circle of the GumBall was 0 on install ! so the only way to get to the setting was to first give it some size in the Advance tab in Properties. shouldn’t it be 4 or 6 by default?
I believe that zero initial size is an intentional change for V6. We did that in Windows too.
