Motion sculpture human body
With two cameras in a calibrated setup this is pretty simple. You’ll just have to shoot rays from the camera positions through the keypoints on the view plane and calculate the line-line-intersections. This returns the closest points on the lines which you can average.
Thats still cool :slight_smile: nicely done.
However what software do you use?for the basic photo pose detection? I tried installing the packages on the PC, but I can’t seem to manage it. Is there a go to way? What additional package would I need to install? Because as i tried it kept asking for packages. The again maybe visualStudio might not be the best platform for it . Might sound silly, but I’m at a learning phase when it comes to scripting.
P.S. found this one. might be interesting as well http://gvv.mpi-inf.mpg.de/projects/VNect/
Yeah I think this monocular detection is also based on PoseNet. Of course, if you have a bone model then you can also use a solver which will try to make it fit to these keypoint lines. With well defined limits for the bones this seems to estimate the poses pretty well (and also fast, at least with C++). But thanks for the hint, I’ll watch out if there is something available for javascript…
I had a closer look at posenet because I was already using another tensorflow library. But you’ll have to find your own way using it with your preferred development environment. There are good tutorials online. I’d start here: https://www.tensorflow.org/install
Edit: But probably you do not even need that. Maybe npmjs then node.js and posenet will already work…
I added a posture tracking to the AR modes in iRhino3D:
Hi @mkarimi
Where can I find the posture tracking and eventually some instruction/examples for use?
Thank you!
We don’t have documentation yet.
But here’s where you find it:
  • Enable AR mode
  • From top right menu, choose Body
  • point the camera to a person and press the human icon on the bottm right corner
@mkarimi Thank you!
I’ve done this but having in my mind what I’m trying to do I pointed the camera towards me…..
But here is the question: can I use iRhino3d to measure the displacement of some markers placed on my foot? Something like in the attached video and eventually in combination with Euglena plugin?
This was possible with Kinect and firefly
That won’t be possible.
The AR mode I added needs to see the whole person in the camera
I understand, thank you!
The body bone pose detection is not useful for that, but you can use Object scan:
Jess
@mkarimi is it possible to get a skeleton?
Hi @martinsiegrist
It is possible to get a structured PointCloud which can be used to create a bone structure and named elements.
To capture poses turn AR mode on and select Body.
Jess
Does that work with a moving body?
No. I’ve clauded an app, which can do that in realtime and record tracked poses.
An alternative way would be to record the video and the synchronized LiDAR data and post process that on pc.
Edit: The body capture in iRhino works with moving bodies - if this was the question?
It tracks bodies pretty fast - but not so precise. It only returns complete captures.
Thanks, yes this was the question. I’ll have to try this
