Hi guys, just logging problems I’ve had switching from Rhino 4 PC to Rhino 5 OSX. So these are wishlist items if they’re not already implemented, or deserving of thanks if there’s an easy solution I just missed because of unfamiliarity.
Item 6 - multiple right-hand palettes. When you have an oversized screen there’s often a lot of blank space in your right-hand palettes, even if it’s e.g., the Layers palette and the Command History. In Rhino 4 you could have 1) object properties, 2) layers and 3) command history open all the time. It seems like the closest way to simulate this in 5 would be to have say three of the right-hand palettes open at once, which for a lot of drawings there would be room for. I think this one’s just a wishlist item, but being able to add a third, fourth right-hand palette would (fair enough, not always) be a boon for efficiency.
