Hello…I hope everyone is doing well.
I have two questions:
1. I want to extrude an object THROUGH a target object, and when I delete the extrusion, I want it to leave a hole in the shape of the outline of the extrusion in the target object. I tried this, but when I deleted the extrusion, the target object did not have the desired hole in it.
2. How do I rotate an object exactly 64 degrees, around a central axis? I have never seen any place where we could do this under ‘Rotate 2-D’ or ‘Rotate 3-D’. It appears to be always free hand rotation. I need to be able to input exact numbers.
Thank you in advance for your assistance.
CarlS
