See the image below:
The size of the circle is about 125 units.
When I try to scale down the size by typing 120 it does this:¨
It is adding the typed value instead of replacing existing one (?).
Fille attached.
polygons.3dm (36.8 KB)
Thanks, I see that.
RH-64916 BoxEdit: Input is added to the existing size
Hi @pascal ,
Me again, different thread, exact same issue. It says here that it’s been fixed but mine is definitely not working properly. I did check and I am using the most current RC. Any other thoughts or suggestions? Thanks for your help!
