Hi Dale,
thanks, that`s what i do now, first check if the replace event has been called before the delete event, and if not, the object has been deleted.
replace = False
def MyDeleteObjectEvent(sender, e):
global replace
if e.ObjectId == id:
if replace == True: replace = False
else:
print "Object Deleted"
replace = False
# remove both events here
def MyReplaceObjectEvent(sender, e):
global replace
if e.ObjectId == id: replace = True
…its probably not the cleanest way
c.
