Hi there,
this might be a bit embarrassing, but I am having trouble with importing custom modules.
The search paths are specified in the options of the PythonEditor of course.
C:/folder1
C:/folder1/subfolder
The superior folder is recognized, but the subfolder is not.
To me it does basically make no sense at all, but maybe I am overlooking something.
The reason I am doing this is to organize my modules a bit more tidy.
I also found a similar issue here.
would it be possible for it to search subdirectories. i imagine a lot of people would have their script repository organized into directories like myself and if you have a lot of folders it’s a pita. thank you.
[2020-10-07 08_39_24-Window]
Thanks,
T.
Hi Tobias,
Is ‘C:/folder1/subfolder’ found inside the following list:
import sys
print (sys.path)
@djordje , yes. Just checked and it is contained in the list.
Okay. Not sure really.
Can you position all the modules as subfolders inside the C:/folder1?
For example:
C:/folder1/module1, C:/folder1/module2 …
I did and now it does not recognize anything at all, @djordje .
It recognizes the following though:
from folder1.module1 import class1
is fully recognized by autocomplete.
When I run it, I get the following:
No module named folder1.module1
Try making the __init__.py file inside each of the C:/folder1/module1, C:/folder1/module2. With the following code inside it:
import file1
import file2
Where file1, file2 are .py files inside the C:/folder1/module1, C:/folder1/module2 folders.
Hi @djordje , I guess this is working.
Thanks first of all.
As Steve described here…
“Python was designed with the concept of modules and packages where sets of scripts are grouped together inside a directory (package). I don’t want to make any change that breaks this behavior.”
My problem is that files from one folder need the other ones.
So it would be a “bummer” to organize them in folders and then having to keep the init files up to date every time you add a new file to a folder, right?
Are there any other strategies to organize the code or do you think I simply have to live with that?
Thanks,
T.
Hm, I see what you mean. Yes, it can be tedious. Maybe someone else has an advice for that.
As I am working with this incredible tool
I thought maybe creating workspaces in vs code might work.
I will test this as soon as I find time and let you know.
Willem
(Willem Derks)
July 14, 2021, 6:28pm
10
Hi Tobias,
The __init__.py files do not need to contain anything they can be left empty.
If you want to load a module from a sibling folder you wil need to add the common root path to the sys.paths like so
sys.path.append(root_dir)
Does that nake sense?
Im on my phone now but let me know if I need to elaborate.
