Modify Surface using Control Points
    RhinoDoc activeDoc = RhinoDoc.ActiveDoc;
    IEnumerable<RhinoObject> brepObjects = activeDoc.Objects.GetObjectList(ObjectType.Brep);
    RhinoObject object1 = brepObjects.ElementAt(0);
    Brep brepBody = Brep.TryConvertBrep(object1.Geometry);
    BrepFace face1 = brepBody.Faces.ElementAt(1);
    NurbsSurface sur = face1.ToNurbsSurface();
    NurbsSurfacePointList pointlist = sur.Points;
    ControlPoint point = pointlist.ElementAt(1);
    Point3d cpoint = new Point3d(point.X, point.Y, point.Z);
    int countu = pointlist.CountU;//9
    int countv = pointlist.CountV;//2
    pointlist.SetPoint(7, 1, 0, 0, 0);
    A = countv;
    object1.CommitChanges();
    activeDoc.Views.Redraw();
Here I have used SetPoint method to set a control point at a given location but the surface havent changed after running the script.
I have a Brepbody and pickedup a surface ->converted it into nurbs surface and want to deform it using control points.
How can I do it ?
latest after this line
you will have a NurbsSurface without any reference to your object1
use AddSurface to see it
To access the surfaces of a Brep see
https://developer.rhino3d.com/api/rhinocommon/rhino.geometry.brep/surfaces
to get the Surface (Index) that belongs to a face
https://developer.rhino3d.com/api/rhinocommon/rhino.geometry.brepface/surfaceindex
but I am not sure what happens if you modify the control points of underlaying surfaces - as trimming / curves also need to be updated.
what are you after - your other post / topics point in similar direction like Push/Pull stuff.
maybe it s easier to build a new Brep then modifying an existing one ?
setpoint returns true, how can I access the new surface?
I want to modify the object by accessing control points. So that I can get new surface/model with such squishy adjustments.
grips
you might be able to access the Breps Grips and modify them.
check out this topic:
setPoint returns true…
as fare as i can see you duplicated a face to a surface “sur”.
Then modify it - the relation to the initial Brep is lost.
Rhino.RhinoDoc.ActiveDoc.Objects.AddSurface(sur);
if you really want to dig into the Brep:
search “build brep from scratch”
and check this for background - another example there…
kind regards -tom
Thank you so much Tom_P, I am trying with the grips. AddSurface worked but it created a new surface.
Will try building breps.
what exactly are you trying to do ?
Maybe handling with vertices of a brep is the wrong approach ?
Simply adding a vertex to a brep to change it s shape is not possible (I guess) because the vertices depend on the typology of the brep.
And please keep your related questions in one place / topic. thx.
kind regards - tom
