Modify isocurves?
Hi there, does anybody know how can i change the orientation of the lines that make the surface. Cause then i want to make a contour but i dont like the original orientation of the surface
i would like this orientation
Hello - please see the attached python -
PlanarFaceDirection.py (7.1 KB)
To use the Python script use RunPythonScript, or a macro:
_-RunPythonScript "Full path to py file inside double-quotes"
A plug-in version - Unblock it in Windows and then drag and drop onto Rhino (7 or later)
PlanarFaceDirection.rhp (16.5 KB)
thank so much
IF i modify the isocurves, does the contour change also?
Hopefully not, using the tool I posted - you tell me if it does!
