is it possible to modify easily a volume in Rhino 3d 6 for Mac like this video (rhino 3d on a pc)
If yes, how can we do?
Thanks a lot for your answer,
best regards,
Nicolas
best regards,
Nicolas
In exactly the same way. Instead of Ctrl+Shift to select subobjects, on Mac it’s Cmd+Shift. Otherwise everything works the same. You don’t actually need the selection filter as shown in the video to do this if you select subobjects with Cmd+Shift+Click.
thanks a lot . One question more… Where I can find this command in the menu?
best regards,
Nicolas
Which command? The Gumball is activated with the button at the top of the Rhino window on Mac.
this command to move a part of the volume with the gumball in Mac (in a pc, you can go menu filter selection and after you can choose “surface/face”)
Thanks a lot,
Type SelectionFilter… should also be a menu item under the edit menu. But it’s not available on earlier versions of MacRhino I believe.
