Est-il possible de modifier le chemin d’un garde-corps sans le refaire (ajouter des points)?
You can edit the railing path trough its control points, which are the same as those from the curve used to generate it. But you cannot add new control points. This is something we could do in future versions.
Ca serait très utile car les garde corps peuvent être très lourds et difficiles à créer. Plus rapide des les modifier que de les recréer à chaque fois…
merci
I understand.
While we create a new command to add jogs to railing paths, check this gh definition out. You just need to:
- reference a railing
- define a new point
- bake the new railing component
- delete the old railing
Railing Add Point.gh (7.7 KB)
PD: this example only works with railings created from polylines
merci pour votre réponse, je ferai comme ça
