What would be the best way to model structures with facets at different angles in rhino?
What approach would be the easiest
step 01:
draw the grid in 2D
step 02:
curveboolean (combineregions=no, allregions)
planarsrf (will make planar surfaces out of your curves)
step 03:
_SelectionFilterVertices
(select points and pull them up)
Let me know if you have any problems
What exactly is curveboolean to be applied to?
P.S for anyone freaking out after enabling _selectionfilter 's
Make sure to disable it or it wont let you select anything and reconnecting your keyboard and mouse 4 times wont fix it ![]()
curveboolean will make curves out of all regions of your 2D base geometry. you can then make them to planar surfaces.
Started with a rectangle and did lines. do you select all and curveboolean?
geo_reviewed2.3dm (131.0 KB)
Cant seem to select the points except the corner 4 of the main rectangle
There are no points there - that’s the middle of an edge.
yes as @wim already said there are no points.
also please be aware that the geometry you were providing earlier contains rectangles and triangles. rectangles will cause a double curvature what you probably dont want according to your initial reference.
would be nice to know how much experience you have in rhino modelling so I know in what detail I have to describe it to you.
Best,
CL
geo_reviewed V2.3dm (507.0 KB)
