These two lines which are cutted with bollean and then connected again, are not properly rendered in Vray. It shoes there is visible mistake in reflections. Do you have some advice or solution how to model it right?
I need import this model to cinema 4D and it needs to be perfect. Please help me I have already tried many options.
The various parts of the ring are closed and cannot join to their mating objects - Join requires open, Un-joined edges from each object. In order to make a clean closed mesh, you’ll need to make a single closed object.
