Hi guys is it posible to import a mesh in rhino and model new geometry ontop of it
Yes⌠with certain limitations. Rhino is primarily a NURBS modeler, although it has some mesh tools. NURBS and mesh cannot be combined directly. So a workflow might be to model the additional parts in NURBS, then convert to mesh to add to the existing object. The âadding to the existing objectâ is the hardest step, as it requires some editing of the original mesh with Rhinoâs limited mesh toolset.
âMitch
Well its not what i want,i want to import a mesh then remodel it in nurbs
You can certainly do thatâŚ
But on top of the meshes surface so i have reference. Any videos available?
Not that I know of⌠Attached below is an older PDF on reverse engineering, the second half covers remodeling a simple mesh object into NURBS.
HTH, --Mitch
ScanCleanupRemodel.pdf (586.6 KB)
This is really helpful! Thanks helvet
And thereâs this:
Cheers,
Ernest
Perfect! This workflow is amazing
wow. long time but thanks!
Is there not a âshrink wrap a meshâ command that will ignore any minute gaps, or not so minute, and bridge them with the shrink wrap ?
I will be looking to convert meshes of 6cm tall model figures to surfaces and need a simple shrink wrap surface, I dont want to have to start editing / creating surfaces as given the complexity of the human form, clothing folds, fingers, faces, and a lot more, it will get prohibitiveâŚ
Can I in fact create a scene with both surfaces and meshes and export the whole lot as stl ?
Steve
Rhino does not have such a function, some other programs do - I think maybe even Blender (free).
Yes.
âMitch
Iâm not sure if itâs covered in the earlier links but there is a command which allows snapping to the surface of a mesh without selecting vertices and points which arenât visible to the camera.
Iâve used it to remodel some scans of some geodes for a client⌠But I canât remember what it was.
It makes it much easier to work with a mesh - if youâre trying to create flat surfaces, using that command and 3pt planes works really well. Just extend the surfaces and trim as you go.
Andy
That would be _CullControlPolygon⌠--Mitch
