I’m doing quite a bit of wheel spinning trying to close a modeless form with a close button instead of the user clicking the “X”. I’ve pasted in some sample code below. I’ve tried a self.Close(), which crashes Rhino and tried what is in the pasted code below with no success. Can someone tell me what I am doing wrong?
Test():
print ("Hi")
# Form Closed event handler
def OnFormClosed(self, sender, e):
print("the form has closed")
# Dispose of the form and remove it from the sticky dictionary
if sc.sticky.has_key('sample_modeless_form'):
form = sc.sticky['sample_modeless_form']
if form:
form.Dispose()
form = None
sc.sticky.Remove('sample_modeless_form')
# Close button click handler
def OnCloseButtonClick(self, sender, e):
if form:
form.Close()
form.Dispose()
form = None
# OK button click handler
def OnOKButtonClick(self, sender, e):
print("clicked")
## End of Dialog Class ##
def Test():
# See if the form is already visible
return
# Create and show form
form = ETOModelessForm()
form.Owner = Rhino.UI.RhinoEtoApp.MainWindow
form.Show()
# Add the form to the sticky dictionary so it
# survives when the main function ends.
sc.sticky['sample_modeless_form'] = form
if __name__ == '__main__':
Test()
I did a test this morning, putting in self.Close() as well as stripping out the Sticky Code and the form closes normally without crashing Rhino. If I reactivate the Sticky Code Rhino Crashes. I’ve pasted the code below. I’ve also posted a video of the Rhino crashing and not crashing after stripping out the Sticky code. The crash is about 1/3 of the way in the video after pushing the Cancel Button.
# Imports
import Rhino
import scriptcontext as sc
import Rhino.UI
import Eto.Drawing as drawing
import Eto.Forms as forms
# SampleEtoRoomNumber dialog class
class ETOModelessForm(forms.Form):
# Dialog box Class initializer
def __init__(self):
# Initialize dialog box
self.Title = 'Identify Assembly Components'
self.Padding = drawing.Padding(10)
self.Resizable = False
#FormClosed event handler
self.Closed += self.OnFormClosed
# self.ClientSize = drawing.Size(300, 400) #sets the (Width, Height)(Optional only)
# Create controls for the dialog
self.m_label = forms.Label(Text = 'Enter Your Name:')
self.m_textbox = forms.TextBox(Text = None)
# Create the default button
self.DefaultButton = forms.Button(Text = 'OK')
self.DefaultButton.Click += self.OnOKButtonClick
# Create the abort button
self.AbortButton = forms.Button(Text = 'Cancel')
self.AbortButton.Click += self.OnCloseButtonClick
# Create a table layout and add all the controls
layout = forms.DynamicLayout()
#Sets spacing between controls(pixels)
layout.Spacing = drawing.Size(5, 5)
#Textbox 1
layout.AddRow(self.m_label, self.m_textbox)
layout.AddRow(None)
#Buttons
layout.AddRow(self.DefaultButton, self.AbortButton)
# Set the dialog content
self.Content = layout
if form:
form.Dispose()
form = None
self.Close()
if form:
form.Dispose()
form = None
print("clicked")
def Test():
return
form.Show()
Test()
Just so I understand this. I disabled form.Dispose() and this solved the issue. Can you explain to me when one would want to use Dispose? I’m unsure of it’s purpose now.
Also, since I have two functions that handle closing the form, one for the ‘X’ and another for the button, do I need to have the Sticky Code in each function or is it only necessary in the function “OnFormClosed”? See below.
if form:
#form.Dispose()
form = None
self.Close()
if form:
# form.Dispose()
form = None
self.Close() triggers your event OnFormClosed() when you click the close button. So you can put your sticky code only there and do not have to do it in the OnCloseButtonClick() function.
I guess this only is usable for modal forms if you want to cleanup memory references after closing it.
