Screenshot: B
Also think i need to change x and y ? Does Y need to look up not down ?
positive Y need to be up, negative y needs to be down if the middle point of this plane is 0
By using “Zoom Extents” with the input of the curve and the Viewport i get this marked objects, which shows the zoom or camera. I am still trying around. But this could be the way.
Thank you for that, now i make a roller coaster Video
I will check it out.
What i am trying to do at en End is somethink like this:
I created this .gh file in the last hour.
I intend to create a diagram showing the drilling deviations of the planned and the executed horizontal drilling.
However, I’m still thinking about whether the plane on which the objects are projected should be aligned vertically (World) or based on the vector of the curve.
