I am trying to place a model to a freeform surface, by vertices.
I had created a surface, and split it with projected gridlines. Then, I have created a model, and place it to the sections by centroid.
The problem is that, when I use surface split, it split to 100 small surfaces with 100 complete surfaces, and lead to duplicated model placement in the middle of the complete surface.
If you don’t want overlapping geometries especially on the negative curvature part of your surface, you could use Surface Morph, but you can’t avoid getting deformed geometries on your surface. If you don’t like deformed geometries, then try to use Orient instead…
Thank you very much for your response.
Currently, I am studying grasshopper on youtube, and facing some issue while using Orient.
In the video, the bricks would tangent to the curved surface, but I am having some issue on the XZ plane.
The bricks always aligning to the X axis, and I have no idea how to fix it.
Video link and Grasshopper file attached.
Thank you so much for helping!
